Floor Panel at Shifter
Old Mar 22, 2021 | 05:47 PM
Turbo86's Avatar
Default Floor Panel at Shifter
I posted this question on the 67-69 General forum section and did not get a response. Was still looking for a solution to repairing this section of floor panel at the shifter. I can simply make sheet metal to match and weld, but there is a secondary square frame that the shift boot frame screws on. Wanted to see if anyone has had to repair this same floor area and how they did it. Its a long shot, but wanted to do my best to repair original.
Old Mar 27, 2021 | 07:05 PM
I did the very same thing on my first 69, decades ago...heated up the arm and bent a dog-leg to center with the tunnel. I formed a piece of metal and riveted in place, since it's not structural. Those were my pre-welding days, today I'd probably keep it fancy and weld it in place.
Old Mar 30, 2021 | 11:56 AM
Turbo86's Avatar
Thank you... I'll make the tunnel repair and see if I can form some metal that matches that square trim. I just removed the subframe, engine and transmission so I now have access to the underside of the tunnel. I think I'll remove that square trim, fix the tunnel and then re-weld the repaired square trim. This way it would still look like that trim is still a separate trim piece welded to the underside. - This would work, Yes?
Old Mar 30, 2021 | 05:37 PM
Zspoiler's Avatar
The aftermarhet makes a preproduction of thst section of the floor that can be welded in .As well as the all the related pieces .
Old Mar 31, 2021 | 07:04 PM
Turbo86's Avatar
Great... Thanks... I'll look on line for that part.
Old May 17, 2021 | 01:25 PM
Turbo86's Avatar
Thanks again Zspoiler... Found the reinforcement piece on line. Have a hard time looking for items when you don't know the name. For those who are looking for the same thing, link below.
https://www.camarocentral.com/1967_1..._p/tra-2pr.htm
Old May 17, 2021 | 02:36 PM
Zspoiler's Avatar
I would gets yourself an assembly as well as other factory manuals for you car .It will help you in the long run.
Turbo86
Apr 15, 2021 01:54 PM
Wayne G
Nov 15, 2013 08:11 PM
IndianScout
Jul 15, 2013 06:36 PM
Time Hybrid
Feb 15, 2010 11:42 PM
420GOAT
May 10, 2007 06:33 PM
