True SS- yes or no factory installed a/c
Old Feb 23, 2009 | 08:16 PM
redzo6's Avatar
Default True SS- yes or no factory installed a/c
A friend is testing me, saying a true SS did not come from the factory with a/c. I said sure it could. Can anyone verify it. Thanks.
Old Feb 24, 2009 | 01:34 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
I will have to look into it when I get home but here is a SWAG. The SS came with a 350 or a 396. I fit were a BB then no probably not. Then again it could have been ordered with one. Of course it also depends on the year. I say no because I would think the A/C stuff would be in the way of a engine- hence the SWAG. (scientific wild a$$ guess) let me double check when I get home and will have an answer for you (if I remember) in about 24 hours.
Old Feb 24, 2009 | 08:30 AM
quadman's Avatar
An SS can have A/c or not, it does not matter.
Old Feb 24, 2009 | 03:39 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
The RPO L78, L79/L89 and RPO Z28 did not have A/C. This is the SS396 and Z28.
So its the Z28 that did not have A/C, not the SS. Unless it was the SS396. This is true for the 67 and 68. I could search the 69 lit I have but am pretty sure its the same results.
Old Feb 24, 2009 | 05:41 PM
mcmcmahon's Avatar
The L35 [325 hp] and L34 [350 hp] SS396 engines , could be had with factory air.
GM did not apply A/C units to solid-lifter motors. like the L78 [375 hp] and
the L89 [aluminum heads] 396ci engines,
L72 [iron block and aluminum heads] and ZL1 [all aluminum motor] 427ci
and the Z28 302 engine .
Old Feb 25, 2009 | 06:22 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Yup, I see it now. I should have gone ahead and dug that little bit more. So to redz06... your friend is wrong. A true SS could come with factory air. Its the Z28 (and perhaps COPO) that did not.
Old Feb 26, 2009 | 09:06 PM
Scooch's Avatar
Super Scooch
January 2009 ROTM
My 69 SS-350 was indeed Factory A/C as well.
|m()d
Jan 23, 2013 04:16 PM
FoMoCo1
Oct 17, 2012 07:14 PM
Chevy101
Mar 31, 2010 04:53 AM
1994z28
Sep 29, 2007 05:39 PM
MochaCaliGirl
Aug 6, 2007 03:15 PM
