smoke out of left tail pipe
Old Nov 19, 2011 | 04:07 PM
Turbo33's Avatar
Default smoke out of left tail pipe
Hey guys, new to the forum, but had a minor question. Have a 396 BB and the last few days I have been seeing white smoke from the left tail pipe only. Nothing that you could see for miles, but its there and obviously a little more as I get into the accelorator. At idle, just continues as well. Any thoughts would be great. No smoke whatsoever under the hood
Thanks!
Old Nov 19, 2011 | 07:58 PM
Thanks!
White smoke sometimes means water in the engine. If it's the left tailpipe I'd guess it's a head gasket on that side. I'd do a compression test on all cylinders and see if it shows any signs on that side.
If you find one cylinder that is low then you should try pressurizing that cylinder with air and then check the radiator to see if any bubbles come up in the top tank. If you get bubbles it confirms a head leak into the cooling system.
Old Nov 19, 2011 | 09:00 PM
thefley's Avatar
December 2012 Ride of the Month
If It's water in oil from cracked head gasket check for water in oil, your oil will look milky. Is it cold where u are? A cold morning just starting engine kind of smoke. Blue snake would mean burning oil, and black usually means running rich.
Old Nov 23, 2011 | 06:34 AM
dynarider33's Avatar
If its white SMOKE it could be valve seals or rings gone bad giving you some blow by. If its white STEAM then it could be a cracked head gasket like BB1971 said. If it is a head gasket more than likely it would run real rough until the engine warmed up.
emilyythestrange
Sep 11, 2011 01:28 AM
emilyythestrange
Sep 10, 2011 07:42 PM
nickb123
Sep 5, 2011 09:38 PM
BOOGYMAN1313
Jun 6, 2011 09:53 AM
Mesosneaky
Jun 9, 2009 03:03 PM
