Sending unit questions
Old Dec 23, 2015 | 01:44 AM
Nik's garage's Avatar
Default Sending unit questions
Hi I am new here to the forums and I have a question about sending units. I purchased a used 69 nova tank to put under the bed of my c10 ( I know, this is a camaro forum) the nova tank came with a sending unit but no lock ring to secure it. All I see online is lock rings for camaro sending units. My question is would a camaro sending unit lock ring fit on a nova tank and sender. Any help is greatly appreciated.
Nik
Old Dec 23, 2015 | 11:38 AM
67-69 Camaro and 68-72 Nova use the same sending unit and components. And the same lock ring fits a lot more than just Camaro and Nova: https://www.npdlink.com/store/catalo...ts-1320-1.html
Old Dec 24, 2015 | 05:20 PM
Everett#2390's Avatar
Hopefully, you have the O-ring with it.
Before install, lube the O-ring with petroleum jelly (Vaseline - brand name) as this will make install and removal a breeze later in life.
A screwdriver by itself makes for a nice tool to tighten the locking ring.
Old Dec 24, 2015 | 05:40 PM
I use the screwdriver & hammerfer installation tools.
Old Dec 28, 2015 | 03:31 PM
To each their own, whatever tool gets the job done without marring the surface/corrosion preventative if applied.
con8quest6
Jun 26, 2007 12:40 PM
microkid
Jan 6, 2007 11:10 PM
budzag@yahoo.com
Dec 15, 2006 12:56 AM
coolcat
May 6, 2006 11:35 PM
ringo234
Sep 28, 2005 04:39 AM
