oil coming out of sending unit?
Old Dec 14, 2006 | 12:41 PM
budzag@yahoo.com's Avatar
Default oil coming out of sending unit?
I have a '92 RS w/ a V-6: it started leaking oil terribly last night, and today I noticed that there is oil coming out of the sending unit next to the oil filter. The wiring harness to that sending unit is unplugged and the inside of the sending unit (where the cable plugs in) is full of oil. What does this mean, will it not leak oil when I plug it back on, or does the sending unit need replacing? Thanks!
Old Dec 14, 2006 | 06:38 PM
FlufyTiger's Avatar
Default RE: oil coming out of sending unit?
If your oil gauge had been reading at all before, chances are the oil blew off the wiring harness. Definitely needs a new sending unit.
Old Dec 14, 2006 | 07:38 PM
Okay, I just installed a new oil pressure switch (sending unit), and re-connected the wiring harness onto it. Now the engine turns over but won't start. I didn't disconnect any cables, and nothing looks out of place. A few weeks ago the fuel pump fuse had blown, could that have blown again all of a sudden? It started earlier today, before I changed the oil pressure switch. Thanks for continued help!
(By the way, this car has a little over 200,000 miles on it, and we've been replacing a lot of components since I acquired it for my son 8 months ago.)
Old Dec 14, 2006 | 09:51 PM
Good news, I just found the fuse for the fuel pump/oil presure switch... it was blown and now it isn't -runs great again! Thanks!
Old Dec 15, 2006 | 12:56 AM
FlufyTiger's Avatar
I may be a little late, but depending on the year, after a certain point, fuel pumps run off of the presence of oil pressure, and if the oil pressure sending unit was messed up, it probably blew the fuse when the oil blew the connection apart. It's actually a really clever idea. The fuel pump only runs on the computer for about 3-5 seconds, and from there opertates on the oil pressure sending unit. When the pressure drops too far, the fuel pump relay cuts off.
May not be much use now, but at least this will help you understand why that happened.
royco95
Jul 16, 2011 10:20 PM
jjz28
Mar 11, 2010 04:04 AM
JordanN
Nov 27, 2009 01:06 PM
97SuperSport
Apr 6, 2008 07:23 PM
maxxiepad
Jun 16, 2007 08:32 PM
