RS limit switches
Old Aug 17, 2018 | 11:47 AM
gmshadow's Avatar
Default RS limit switches
Would it be correct to think that when the diagram refers to inner and outer switch that the inner switches are on the radiator support and the inner are the ones mounted to the headlight assy?
Old Aug 17, 2018 | 11:39 PM
peterpar's Avatar
The diagram doesn't label the switches as inner and outer, but if you look at the drawing it shows the switches on the radiator wall being fed with the dark blue wire and the opposite switches fed by the brown wire. As long as the switch were wired that way, they should operate correctly. I guess if you were to name them, the radiator wall switches would be the inner and outer would be on the headlight assembly. You may also want to pay particular attention to making sure the wires are connected to the switches as shown on the drawings. When any switch is depressed by the headlight door, it should close the contact to complete a path to ground.
Old Aug 18, 2018 | 11:39 AM
gmshadow's Avatar
Thank You, I"m hoping the under the dash wiring is still intact. Car coming along slowly and hope to be able to drive it in a couple weeks
Charles.
Old Jun 11, 2020 | 11:35 AM
ron 1967's Avatar
The pressure switch I need to connect the wires to are in the Headlight housing, Good news, I just looked in my Camaro restoration book and found a wiring diagram: 2 wires brown on the top and single blue wire on the bottom. Thanks !!!
gmshadow
Feb 2, 2021 10:22 AM
mikes67
Aug 1, 2019 04:02 PM
Big Ern
Jul 1, 2018 11:42 AM
Tyler_2118
May 14, 2018 05:49 PM
Shooterrobb
Apr 25, 2014 05:33 AM
