Led headlights
Old May 4, 2018 | 07:12 PM
Tyler_2118's Avatar
Default Led headlights
installed led headlights today, and my rs doors wouldn't close anymore but would open. Then I realized they wouldn't close because when I turned the headlight switch off they didn't turn all the way off they had a very dim light to them. They were the direct replacement plug in kind so I didn't have to do any wiring. Any ideas why they won't turn all the way off?
Old May 8, 2018 | 03:47 PM
Everett#2390's Avatar
Swap in regular headlamps in engine compartment and see if the doors close.
Ensure the ground wire from headlight connector is in good condition, as in removing them and wire brushing both the terminal and radiator support.
Might even run a test jumper from support to battery neg terminal.
Old May 8, 2018 | 03:57 PM
Tyler_2118's Avatar
Yea the doors close when I put the originals back in. I am going to try some 2ohm resisters this weekend and I'll double check the grounds. Hopefully that works. Thanks for the reply.
Old May 14, 2018 | 04:14 PM
Smee78's Avatar
Have you tried contacting the manufacturer? They may have seen this before and know exactly what to do? I'm curious because I was thinking about installing a set into my 68 once its back on the road. Do you have a link to the ones you tried?
Old May 14, 2018 | 05:49 PM
Tyler_2118's Avatar
I don't have the band right now. But I put 6om resisters on the bright side and it fixed the problem and the rs doors work again.
Tyler_2118
May 4, 2018 07:06 PM
carid
Oct 30, 2015 10:04 AM
Fairly_Clueless
May 22, 2012 01:40 PM
Phil 2001
Aug 21, 2008 05:33 PM
