replacement antenna
Old May 3, 2007 | 11:18 PM
skar's Avatar
Default replacement antenna
Any body know if some one makes a replacement Antenna that is short ? 4 to 6 inches long. So car cover will fit with out cutting hole.
__________________
[/align]
Old May 4, 2007 | 09:29 AM
Blade's Avatar
June 2007 ROTM
Default RE: replacement antenna
u can get aftermarket ones. they have shorter ones but they are rubber. Why not just unscrew it when ur putting the cover on it?
Old May 4, 2007 | 11:37 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Or get a retractible one?
Old May 4, 2007 | 02:27 PM
skar's Avatar
ORIGINAL: Blade
I cant find one. So I made one from some stainless at work 6" long. ? if it will work but it fits nice and looks good. Now I need a new radio.
Pain in the *** taking it off and on every time.
Old May 4, 2007 | 11:41 PM
A plain 6" piece of metal won't pull much of a signal. An antenna that short requires to be built wit a loading coil in order to pull a decent signal.
Old May 5, 2007 | 04:53 AM
1969 SS's Avatar
what about a power antenna or an "antenna-less" antenna. they usually go above your headliner. gives a way smoother look to the car
Old May 5, 2007 | 11:16 AM
skar's Avatar
ORIGINAL: z28pete
Thanks. I think I will cut a hole in the cover.
Old May 5, 2007 | 02:46 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Have you checked ricks?
Chevy101
May 29, 2011 01:49 PM
defigart
Sep 19, 2010 03:12 AM
cautioncones
Dec 27, 2008 06:06 PM
FUZZYDP
Nov 2, 2008 09:25 PM
shnormo
Oct 11, 2006 06:06 PM
