Rear end prob.
Hi all, new to the forum and im really loving, it Sooooo much info. I bought a 68 camaro with multi leaf springs but it is a 10 bolt mono leaf axle so im thinking about buying a 12 bolt multi to replace it. here is my question, will i need to change the drive shaft or will it be same length? i have a th30 tranny in it.
Your probably going to have to have the driveline shortened by an inch or so. I don't know the correct difference, but if you put them side by side you can see the pinion sticks out about an inch or so longer on the 12 bolt.
I have never had to change my driveshaft when changing those types of rearends but if you want to be 100% sure, just take your measurements before you take the old unit out and after you put the new one in
