LED lights
Old May 10, 2012 | 06:51 PM
sgreg831's Avatar
Default LED lights
Hi, new to the forum. Just bought a 69 camaro and wanted brighter tail lights. Will LEDs work? Will they be brighter? Do I need a new flasher? Or are they plug and play? Thanks in advance.
Old May 14, 2012 | 01:57 PM
jeu510's Avatar
should come as a kit depending on who you buy it from.
Old May 23, 2012 | 07:42 AM
dsego's Avatar
I ordered two LED 1157 type bulbs from superbrights.com and they worked out great. I bot the brightest ones they had. I was told by them to always match the LED color to the lens color. I put in red ones and the work great at a cost of about $25 each. They are brighter than stock. I tried white ones of the same type but they did not seem nearly as bright as the stock bulbs. You can select your car and their site will show you all the led replacement bulbs for your car. And yes, you will need an electronic flasher. The only incandescent bulbs in my car interior or exterior are now LED,s. I get lots of positive comments.
pojo1988
Aug 27, 2017 09:35 PM
98Z28ImportSlayer
Mar 16, 2012 09:07 AM
Bing
Sep 20, 2010 08:09 AM
bodykits
Jul 1, 2009 09:52 PM
91 RS
Feb 24, 2007 11:14 PM
