Intake ID?
Old Nov 2, 2008 | 05:59 AM
greybeard's Avatar
Default Intake ID?
I have an original block and heads that cameout of a wrecked '67 295/350. The carb-less intake manifold was pulled and set on a shelf along with about 20 others where it sat fora good number of years. Irecall that itwas aQjet, althoughmy memorymay befaltering....Unfortunately, it didn't get tagged or marked andI may have given it away over the years. I've looked at a bunch of sites on line with no luck. Can anyone providethe correctcasting number for the 295/350 intake so that I can keep looking.
The only cast ironintake I have left is a "GM2 3888848" (Holley pattern) and was hoping that someone might be able to ID it as well -the number popped once on Google but didn't provide an id.
Old Nov 2, 2008 | 07:24 AM
Ircyklops's Avatar
Default RE: Intake ID?
Ifthe numbers are hard to make out on that3888848 intake, it may be 3883948 instead, which would make it a 1967 or 1968 396 intake. And the numbers for the '67 350 should be;
3905393
4BBL Rochester
1967
327
275
350
295
Check out the link below.
http://www.chevy-camaro.com/parts/ch...des-intake.htm
crimson09
Dec 15, 2018 07:07 AM
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
antbradley100
Mar 12, 2011 05:11 AM
tuletymeZ28
LS Series Tech
Aug 22, 2010 12:12 PM
z28rob18
Jun 22, 2009 04:40 PM
