High Output Alternator
Old Mar 25, 2019 | 06:32 PM
roscoe's Avatar
Default High Output Alternator
Recommendations for a replacement alternator. Current alternator output less than 14 volts. I am considering a higher output unit and need a recommendation on amp rating. Thanks!
Old Mar 25, 2019 | 07:03 PM
Unless you are running a lot of extra stuff on your car a stock alternator should be all you need but if you think you need more 100 amps should be enough for most applications.
Old Mar 25, 2019 | 08:24 PM
roscoe's Avatar
Running an electric fuel pump and dual electric fans. Thanks!
Old Mar 25, 2019 | 11:18 PM
Al Loyrat's Avatar
Which Alternator? . This might help. I ran a 100 amp Powermaster when it was enough. Now I run an MSD 160 amp for the extra stuff I've added which includes electric water pump and electric crankcase ventilation pump. I run a 5 foot 4 gauge wire to the battery with the 160amp. Voltage drop from the batt. to alt should be less than .5 volts (not running). Alt operating rpm range can be adjusted with pulley ratios.
Old Mar 26, 2019 | 04:33 PM
SoCal67's Avatar
check your EL fan wiring requirements...often they are 20-30 amps each. Fuel pumps are not much but I would allow 10 amps for that circuit unless install instructions say more.
Those 2 "extras" take you to at least 100 amp alt. If you have a big a$$ stereo...go more
dorn4ever
Jun 25, 2014 06:12 AM
c_anderson180
Oct 12, 2012 02:47 PM
bucko1990
Mar 30, 2011 07:21 AM
Str3tch
Oct 30, 2007 07:56 PM
Number1Dad
Jan 29, 2007 05:42 PM
