alternator
Old Jun 20, 2014 | 12:22 AM
dorn4ever's Avatar
Default alternator
Hey all just wondering if anyone can tell me what the stock alternator is in a 1995 z28 it has a/c if that matters is it a cs144 or cs130? are the cs144's the 140 amps? looking for an aftermarket alt if anyone has an opinion feel free to express it. maybe want to get a pretty one since almost the entire thing is visible. Thanks. ps either way I do need a new one.
Old Jun 20, 2014 | 05:45 AM
Everett#2390's Avatar
I would get one from RockAuto.com
Old Jun 20, 2014 | 07:16 AM
GaryDoug's Avatar
CS-130 is for the 3.4L-L32 engine. There are at least two versions of the CS-144 for the 5.7L-LT1 engine: 10480131 (124 amps) and 10480111 (140 amps). I believe the 140 amp one is the replacement for the 124 amps alternator. The number after the "CS" indicates the diameter of the stator in mm.
Old Jun 20, 2014 | 07:38 AM
Old Jun 24, 2014 | 01:09 AM
dorn4ever's Avatar
hey thanks guys, yeah ive been looking at the tuff stuff 200 amp from summit p/n 8173NEP. Is that going to be a simple bolt in and plug in job or am I overlooking some important detail? Otherwise may go with the rock auto ac delco not a bad price.
Old Jun 24, 2014 | 10:20 AM
looks like a direct fit. i have this one and was a perfect fit. http://www.summitracing.com/parts/pw...t/model/camaro
Old Jun 24, 2014 | 10:31 AM
rock has some good acdelco units. get the 140 amp.
Old Jun 24, 2014 | 12:46 PM
Be careful going 43% bigger than what the factory provided (140 to 200 Amp) as the wiring may not be able to handle the extra amps. The wiring protected by fuses will survive, but fusible links and some cables may not, and go up in smoke.
Old Jun 25, 2014 | 01:23 AM
dorn4ever's Avatar
I was thinking that could be a problem. What would I all have to change and what gauge wiring would I have to use? or would I just be blowing fuses all over anyway? I will take your word for it if you think I just shouldnt do it at all. The work and wiring i can do just dont know what. The other alternator i want (the tuff stuff 140 amp 8173NAP) I cant find anywhere. summit doesnt actually have any. They even ended their ebay auction for them.
Old Jun 25, 2014 | 06:12 AM
140 amp is not going to hurt your wiring. I'm using a 200 amp an wiring is fine. i added a extra ground wire to alternator for piece of mind and that was it.
WIspartan1026
Jun 7, 2011 04:36 PM
94z28chevy
Jul 20, 2009 03:37 PM
lovelacci
Aug 14, 2007 12:39 AM
joeyninetoes
May 18, 2007 03:33 PM
92ChevCam305
Dec 26, 2004 03:50 PM
