HELP Identifying V8 engine
Old May 14, 2018 | 09:11 PM
  #31
sptrucksbyed's Avatar
I have 396 motors but still ended up using a 468 !!
Old May 15, 2018 | 06:52 PM
  #32
Y2K's Avatar
Y2K
Originally Posted by Al Loyrat
The compression height was taller on the pistons when a 6.135 rod is used. Where the water pump attaches to the block, the top of the upper mounting ear of the water pump will be even with the deck on a 9.80 deck block; on a 10.20 deck the top of the water pump mounting ear is .400" below the deck of the block.
Yes but weren't those just in heavy trucks like dump trucks and 2 1/2 ton box trucks etc.? Aren't pickups and Suburbans the short deck like cars?
Originally Posted by Gabet95
So I should be looking for a 454 from 74 or earlier, make sure it came out of a passenger car......that would be the ideal setup to start with.....right?
1970-1972 would be best before they went low compression and smogged out. Those of course would be harder to find. I'm pretty sure pickup trucks and Suburbans had the short deck 454 up through about 1990. After that they still had 454's but there were some changes like no place for a manual few pump to bolt on. If you go looking for a 454 probably 9 out of 10 you find will be mid to late '70's pickup/Suburban or motorhome engines.
Old May 15, 2018 | 09:27 PM
  #33
Al Loyrat's Avatar
Verify the deck height before you buy it, and remember the gen IV & V big blocks are different than a Mark IV big block. What car do you want to put a big block in?
Old May 15, 2018 | 09:29 PM
  #34
Al Loyrat's Avatar
454 bored .060 over.
Old May 16, 2018 | 07:15 AM
  #35
Gabet95's Avatar
Good info.....thanks
Old May 16, 2018 | 07:20 AM
  #36
Gabet95's Avatar
I’m looking to swap out the 327 in my 1968 Camaro. I was hoping it would as simple as just swapping both engines and changing out the front heavier duty suspension spring to compensate for the heavier engine.
Old May 16, 2018 | 08:29 PM
  #37
Y2K's Avatar
Y2K
You will need to swap out the heater core, small block heaters end up with the hose connections to the core right behind the cylinder head with no room to hook it up to the hoses on a big block swap.
RichTJ99
Jan 17, 2012 10:54 PM
jh23job
Aug 10, 2009 07:25 AM
Axel
Apr 29, 2008 12:05 AM
sapperford
May 13, 2007 02:25 PM
sapperford
May 13, 2007 02:24 PM
