Help with big block ID
Old 06-09-2014, 12:35 PM
mastiffd's Avatar
Default Help with big block ID
A friend just purchased a 56 Chevy with a BB in it.
I can't get to the cast number or year code from the back of the motor and was only able to get the numbers off the block deck.
I can't seem to identify the motor using the codes and internet sites so I'm hoping someone here can help me.
Here are the codes…
T0928ED H B110675
1968 396ci 325hp perhaps?
Thanks you in advance for assisting.
Old 06-09-2014, 03:51 PM
T0928ED...
T=Tonawanda engine plant
09=September (9th month)
28=28th day of the month
ED=325 hp 396 out of a Chevelle, 1966, 1967, or 1968.
You would need to look up the date casting on the bellhousing flange to determine which year it is.
Or, if that B in the second set of numbers is actually an 8, then the engine would be a 1968.
Chevy Camaro Big Block Engine Suffix Codes
Old 06-10-2014, 04:55 AM
camaro396's Avatar
I have a bb396 in my 67 Camaro and I am not sure on the type of engine either. I don't even know if it is a 396 I am only going by the sticker on the air filter.
My engine numbers stamped in front of the passenger cylinder head is:
0123 7N198833
can anybody help????
Old 06-10-2014, 07:50 AM
Start your own thread so you don't hijack this guys.
Look for a pad on the front of the engine above the timing chain cover for the suffix code build info. What you gave is the partial VIN info: not knowing if you really have a 396, 7 would suggest 1967, N for Norwood plant, 198833 is the last 6 digits of the car the engine goes with. If those 6 numbers matches your car, you have an SS model with a matching engine, and it is indeed a 396.
decaen
02-16-2012 01:08 AM
tecumseh
03-08-2011 01:01 PM
gadmhahn
10-09-2009 09:20 PM
acarius
04-07-2009 05:53 PM
Carinhas
67-69 V8 Tech
13
08-23-2007 05:02 PM
Quick Reply: Help with big block ID
