Help with 67 exterior molding/trim install
Old Feb 7, 2009 | 02:31 PM
kloberemt's Avatar
Question Help with 67 exterior molding/trim install
I have a 67 and am putting some of the original chrome exterior trim/molding back on that came off the car. I have looked through my books, but have had no luck helping me with the install. It looks very simple, but I feel I am missing some parts as it does not make sense. I have installed what I think is called the weatherstrip retainer (the upper rail that is 2 parts where the door glass meets the top of the cab). I know weather stripping goes in there as well, but what does the chrome rain rail molding clip to? If this does not make any sense, I would be happy to post some pictures. Thanks
Old Feb 7, 2009 | 02:50 PM
kloberemt's Avatar
A few pics, just want to get the chrome door molding on the car. Thanks
Attached Thumbnails Help with 67 exterior molding/trim install-dsc_1198.jpg   Help with 67 exterior molding/trim install-dsc_1195.jpg
Old Feb 14, 2009 | 01:45 PM
mikebrow74's Avatar
The chrome drip rail molding simply clips over the roof drip rail. If you look at the back side of the trim piece you will see that the rolled edge is deeper on the top and has a shallow roll on the bottom. You should have three pieces.
Start at one end by placing the top lip of the molding on the back side of the drip rail. Now roll the bottom edge on to the botom of the roof rail until it snaps into place. Continue the full length. The chrome trim has a slight convex shape so avoid pushing on the center of the trim, it will bend and show as a dent. Apply pressure only to the edge of the trim. Sometimes a 6-inch length of soft 2x4 will help coax a stuborn section on. Do the same for the A pillar trim. Last is the corner piece which joins the two. This piece is applied in the same manner but you will need to close the tabs around the bottom to keep it in place.
Old Apr 22, 2011 | 07:35 PM
gold 67 rs's Avatar
yet a book got from libraary says to apply 1/4 bead of medium sealer along full length of inner attaching surface this is from a fisher body service manual
rockinjohnny
Apr 13, 2013 11:03 AM
puma
Aug 1, 2011 10:26 AM
redsoxsstink
Sep 21, 2010 01:18 PM
dbess23
Nov 22, 2008 07:02 PM
David56
Nov 3, 2008 11:36 PM
