Heads for 350
Old May 9, 2008 | 09:06 AM
buckmaster's Avatar
Default Heads for 350
What heads would have come with an ss350 engine? And what valves?
Old May 11, 2008 | 08:09 AM
Ircyklops's Avatar
Default RE: Heads for 350
this may help
http://www.camaros.org/l30m20.shtml
1968 casting number= 3917291***
327/275, 350/295
Temperature sending boss tapped for sending unit.
*Large valve versions of the same casting were used by higher performance engines like the 302.
**All had a double-hump casting symbol, 63.305-cc chamber, 1.94-in. inlet, and 1.50-in. exhaust.
***A very late build, T0702EE, example of an L30 engine with 3947041 heads (casting normally attributed to 1969 model use), dated F018/F268, has been found. These heads do not have the drilled and tapped 1969-type accessory holes.
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
