Dumb Question Where is oil filler plug?
Old Oct 27, 2010 | 10:17 PM
I Need Speed's Avatar
Default Dumb Question Where is oil filler plug?
Is this it? Just pops out right? It is Edlebrock, so aftermarket correct? So I just pull it out and pour away? Thanks
Old Oct 27, 2010 | 10:28 PM
Right. Might be a snug fit in the rubber grommet, but it pulls out, with a little twist too if needed.
Old Oct 27, 2010 | 10:30 PM
Thanks bro! I feel dumb, but hey, if you don't ask you you will never know right. I started to pour it in my power steering pump. HAHA!
Old Oct 27, 2010 | 10:32 PM
Oops, better get all that stuff out of the pump. Motor oil isn't a hydraulic fluid.
Old Oct 27, 2010 | 10:38 PM
BTW, You car looks sick! If I pulled next to you at a red light I would just look the other way and pull off slowly! What kind of HP does that thing put out?
Old Oct 27, 2010 | 10:50 PM
Thanks. Estimated is somewhere in the 450 range. Haven't had it up on a dyno yet, local place shut down before I got a chance to.
Old Oct 28, 2010 | 11:26 AM
hkunz's Avatar
Remember when you drain the PS system, jack the front end up, put jackstands under it, and cycle the steering back and forth until you get it all out, then again after you button it up and refill it. There will be bubbles at first, and your pump will make noise if you don't bleed it.
Luz Hernandez
Apr 19, 2011 08:25 PM
Chevy101
Apr 29, 2009 07:51 AM
camaro98
Feb 3, 2009 01:10 PM
IshZ28
Sep 13, 2008 12:41 PM
eskimoobob
82-92 V8 Tech
Sep 20, 2007 08:47 AM
