Driver Side Door Lock Question
Old Jun 15, 2007 | 02:27 PM
FrankCastle's Avatar
Default Driver Side Door Lock Question
Hello there,
I have a problem with getting into the drivers side door of my 1968 Camaro. I have taken off the door panel and to get in, I unlock my passengers side door and lean over to the driver side. I reach into the door frame and using my finger physically flick the door assembly to the unlocked position.
This succesfully unlocks my door so that I can open it from the outside. This is the only way to open my door from the outside.
The key will not unlock the door yet the door lock assembly is working. Is there a length of cable that can be replaced which will allow me to open the door from the outside?
Thank you so much for this forum and hope everyone has a great weekend.
-Frank
Old Jun 15, 2007 | 04:31 PM
southernspeed's Avatar
Default RE: Driver Side Door Lock Question
I have the same trouble with my wife's '67. If I jiggle the lock back and forth (lock and unlock) several times it will usually unlock. You can't pull the lock up from the inside though. If I find out what it is I'll post up!
Old Jun 16, 2007 | 11:34 PM
1969 SS's Avatar
all there is in there is a metal rod that goes from the lock cylinder to the lock(the rod you pull up and push down). I don't know how it would have happened, but it seems that the rod came out somehow. the easiest way to fix it, because it would be hard to explain online, would be to take your passanger side panel off and look at the assembly to see how they hook together.
I would think there should be a rattle in your door as you are driving or maybe if it fell off, it is sitting in the bottom of the door
Old Jun 17, 2007 | 06:59 AM
Blade's Avatar
June 2007 ROTM
hey punisher it sounds like the nut came off that holds the rob to the mech that unlocks the door.
jshwllngtn-91
Mar 2, 2012 08:55 AM
Chaotic94
Jan 23, 2011 08:39 PM
leelo
Jul 1, 2009 09:58 AM
CamaroKid12001
82-92 V8 Tech
Mar 13, 2009 08:39 AM
