BB radiator with a 327 engine???
Old Feb 9, 2008 | 04:51 PM
1968 RS's Avatar
Default BB radiator with a 327 engine???
I have bought a 23 inch big block radiator and BB fan shroud for my 1968 327 Camaro. I have not got it installed yet but at first glance it looks like the fan will be about 2 inches back from the shroud instead of just inside the shroud as it should be. Has anybody tried this set up? If so what do I need to do to make this right? I’m beginning to think I made a big mistake buying these parts. Any help would be greatly appreciated.
Old Feb 9, 2008 | 11:50 PM
firebird69racer's Avatar
Default RE: BB radiator with a 327 engine???
Use the small block fan shroud not the big block shroud. it will be just a little shorter on the sides but will work. I did it in my Firebird when I put in a small block Chevy, they use the same big block Chevy rad. Or you can just get an electric fan
Old Feb 10, 2008 | 09:53 AM
sweet1967camaro's Avatar
If I read the post right, all you should need to do is put on a 2 inch fan spacer. that should bring it up 2 more inches to the radiator.
Old Feb 10, 2008 | 08:56 PM
ORIGINAL: sweet1967camaro
Wont work. The BB shroud it offset from the SB so it dont line up good enough to just extend the fan out
Old Feb 10, 2008 | 10:00 PM
1969 SS's Avatar
I really don't understand your thoughts behind buying a BBRadiator for a SB. is this a stock replacement? if you wanted more cooling,all you should have done was buy a radiator with a thicker core. where did you buy the radiator?
Old Feb 11, 2008 | 05:23 AM
MichiganMan's Avatar
January 2008 ROTM
Have you ran the engine as it is set up now? what is the temp? thought about just putting in electric fan set up? When i bought my car it had a big block motor and a small block radiator w/no shroud. I of course swapped eveything out went with a becool big block rad w/ dual cooling fans.
Old Feb 11, 2008 | 07:33 AM
1968 RS's Avatar
Thanks for your help. I bought the BB radiator by mistake from a half a** radaitor shop thatspecial ordered it. It has been a month or more & I don't even know if I have the paperwork from it. I have not run the engine with the radiator since the car is in the process of going through a major frame off restoration. I doubt that I can get this place to exchange it but I will try today, if not I will be selling this radiator and fan shroud. $300.00 for both will take them, let me know if anybody would like to have them.
Old Feb 11, 2008 | 10:05 PM
ORIGINAL: 1968 RS
Did you give them the part number or did they pick it out and order it? If they ordered the wrong one and you have not installed it they should exchange it for the right one.
Old Feb 12, 2008 | 07:30 AM
1968 RS's Avatar
I talked them into swaping out the BB radiator for the correct SB three core radiator today. Now I need to get with Tamraz in Illionis and see if I can get them to give me a credit on the fan shroud. Thanks for the help.
capteasy300
Sep 23, 2010 12:17 PM
jj350
Aug 7, 2010 01:20 AM
ronzem
Sep 12, 2009 11:53 AM
kamaro68
Mar 30, 2008 10:37 PM
