Another question on timing
Old Feb 10, 2019 | 11:49 AM
Buchananr's Avatar
Default Another question on timing
69 Camaro with a 350.
With the distributor out and when I bring the number one piston to the top on the compression stroke the mark on the harmonic balance is straight up at 360. Is that where I want to start or do I want to bring the mark to 4 degrees BTDC then drop the distributor in and fine tune it from there?
Old Feb 10, 2019 | 12:00 PM
When you start to feel pressure, the piston is approaching TDC, it's not all the way there yet. You then want to line the marks up at 0, or 4 BTDC if you want, drop distributor in, then fine tune from there.
Old Feb 10, 2019 | 12:49 PM
Buchananr's Avatar
And when it's at zero degrees the contact on the rotor should be pointing in the direction of the #1 cylinder??
Old Feb 10, 2019 | 05:53 PM
Correct
Old Feb 10, 2019 | 06:19 PM
Buchananr's Avatar
Thanks very much. I really appreciate your help.
B_Dubya
Dec 20, 2017 01:02 PM
nebraska83Z28
82-92 V8 Tech
Dec 6, 2009 10:49 PM
waffles
Sep 12, 2009 11:03 PM
Aram
Feb 22, 2007 10:51 PM
wildazme
Jan 16, 2005 05:56 PM
