69 Camaro won't shut off
Old Mar 20, 2007 | 11:16 PM
BradsCamaro's Avatar
Default 69 Camaro won't shut off
Hi, I have a '69 327 with a 3-speed manual. It starts fine but now when I turn the key off, the ignition won't shut off. Is this caused by the rod being out of adjustment that leads to the switch? Looking for answers on how to go about fixing it. Thanks!
Old Mar 21, 2007 | 08:33 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: 69 Camaro won't shut off
How did you finnaly get it to shut off. Its not still running is it? Could be in the switch.
Old Mar 21, 2007 | 09:15 PM
I did get it to shut off by choking it and then I disconnected the battery cable to turnoff the power. I'd hate to keep feeding it gas at these prices! I was told at a local auto parts store that the rod to the ingition switch is likely bent out of position to shut it off. I can find no easy way to reach it.
Old Mar 21, 2007 | 10:37 PM
tommynos's Avatar
July 2007 ROTM
mine wont shut off only if a mustang is present...lol...seriosly,sounds like the ignition switch for sure...
Old Mar 22, 2007 | 06:43 PM
Does anyone know the procedure on replacing the ignition switch? I'm guessing you have to drop the steering column to get to it or hire Mini Me to go in there and reach it.
Old Mar 22, 2007 | 08:34 PM
tommynos's Avatar
July 2007 ROTM
If yours is in the colum,i believe you have to pull the steering wheel and look for a relief button to push...but im not 100% on that.....if you have AAA call and say you lost your keys,even if a friend has AAA they will come out and do it for free(they did my 89 vette,which was a pain)...but my car has the switch on the dash and it would shut off and id have to wiggle it to keep it running,it was easy to replace...
Old Mar 24, 2007 | 12:12 AM
sweet1967camaro's Avatar
If the ignition is on the dash its easy to fix, just a little hard to get too. Fairly cheap $15. Theres some tips here on the internet to help you out. If your ignition wire (red on mine) is going into the fusebox on the passenger compartment side is one plug-in lower than it's supposed to be it will start but not shut off. Try playing with that a little bit.
Old Mar 26, 2007 | 06:44 PM
Thanks for all the tips and advice, guys. It all seemed to work fine the last time I used it but I did notice now that on the steering column which looks all original, there's a part of it near the dash that rotates and when I rotate it it will turn just enough for the key to move more smoothly. In some positions it will cause the key to not go fully into LOCK or ACCESORY. Not sure why this thing turns but it looks like it might be related to cars that might have had the automatic stick on the column but there are no holes drilled anywhere on it.Now the key works sometimes to shut it off but there still must be something binding in there. I'll do some more investigating.
Old Mar 27, 2007 | 12:21 AM
Problem solved!! Sweet67Camaro was right on with the fuse box. I looked at the fuse box and the stupid stereo filter wire was touchinganother bare wire to the igition fuse. They weren't even taped, just bare connections. I pulled them away from each other and taped them up and she now shuts off like she should. Thanks again everyone! This site is the best! I'll have some more questions coming up soon!
weasel348
Jun 18, 2012 10:07 PM
dogdog130
Feb 16, 2011 02:36 PM
rileyz28
82-92 V8 Tech
18
Jun 6, 2008 02:50 PM
chaos
Sep 18, 2007 06:20 AM
rocksolid
Aug 15, 2006 04:51 AM
