will not shut off
Old May 13, 2008 | 09:39 AM
rileyz28's Avatar
Default will not shut off
hey when I turn the ignition off my car still wants to keep running but it acts like it sputters and like just keeps going I dont know how to explain it
Old May 13, 2008 | 10:58 AM
Default RE: will not shut off
Sounds like you may be describing run-on (dieseling)?
1) Is your engine running hot?
2) Severe carbon deposits on the pistons and in the heads can cause hot spots that can make the fuel keep burning after ignition is switched off.
3) If you hot-wired your cooling fan, and if it's still switched on when you shut down, it can act as a generator as it's free-wheeling and give your ignition a power feedback to allow the engine to continue running for a couple seconds.
Old May 13, 2008 | 01:30 PM
irocktheIROC's Avatar
ORIGINAL: Camaro 69
no no no....my diagnosis? ITS POSESSED!! THAT THUR KAMERO IS EVIL!!! just kiddin we all know camaros are eveil...
Old May 13, 2008 | 01:52 PM
ORIGINAL: irocktheIROC
ORIGINAL: Camaro 69
no no no no....the real problem is that Camaros are so great, they just won't die!!! Yeah, that's it!!!!
Old May 14, 2008 | 04:59 AM
all of the above....Camaros are amazing friends, yes, i treat mine as a friend...i even tuck it in..Hahaha
Old May 16, 2008 | 06:05 PM
oneals camaro's Avatar
Im just putting this out there but maybe the throttle cable is set to high? But i don't know anything so you shouldn't listein to me.
Old May 20, 2008 | 07:00 PM
94z28chevy's Avatar
i now my friends ford truck with a 429 cobra jet duz that to but it stops when he run 93 octane
Old May 20, 2008 | 07:08 PM
73camaroSS's Avatar
thats cause itsa ford duh
Old May 20, 2008 | 11:38 PM
383 79's Avatar
Hey, mine does that. Although my engine is set up completely different then yours, I do have a temporary solution of sorts. I have to have my idle way up, because my engine is really cold-blooded. It wont stay idling in gear unless its really warm. Basically, at operating temp, my engine idles at 900-1000 in gear, but in park or neutral, it goes up to like 1500-2000. If I shut my car off at the higher rpm, then it diesels for a good 5 seconds. To get it to shut off clean, I have to put it from reverse, and then park, and turn off my ignition before my rpm increases.
I have heard of a mechanism that ford used on their cars in the past, that I think acts like a choke. so it starves it as you turn it off. But, I'm not sure. I've just begun to look into it, I really don't like monkey business with my car. I just want to fix it right lol. I'll tell you if I come across anything.
Old May 21, 2008 | 02:07 AM
MadMikeZ28's Avatar
383
Does your idle high so it will not die when you put it in gear? If so then you may want a stall converter.
And another thing people should check is their timing. It can cause hot spots. Has any one ever had thier timing so far off it caused their exhaust manifolds to glow?
