69 Camaro Cowl induction linkage adjustment
Old Oct 19, 2015 | 08:45 PM
moose69's Avatar
Default 69 Camaro Cowl induction linkage adjustment
I purchased the aftermarket detent switch and clip that its slides into. I take it this was a poor setup. The plastic detent switch energizes when you push the linkage ¾ of the way down and then energizes the solenoid to open the flap. The issue I am having is the detent switch at times binds and then sticks as it pushes against the firewall. Was this a terrible setup from the factory or is the aftermarket parts I am using. It just seems to be not a stable setup.
Old Oct 22, 2015 | 07:10 AM
Everett#2390's Avatar
Poor aftermarket materials as OE switch is metal.
You might spray the plastic with WD40
blakeyon2asd
Nov 29, 2014 08:52 AM
mikes77camaro
Aug 28, 2008 01:32 PM
91CamaroGuy
Oct 29, 2007 06:00 PM
hateandanger
Dec 11, 2006 09:13 PM
