How to adjust parking brake on JL8 disc
Old Oct 22, 2015 | 08:44 PM
ZL1's Avatar
ZL1
Default How to adjust parking brake on JL8 disc
How do you adjust the parking brake on the JL8 rear disc option. I am not talking about at the cable but at the rear calipers themselves? The levers are pulling as far tight as they can. There must be an internal adjustment between the lever shaft and the piston?
Old Oct 23, 2015 | 11:41 AM
Everett#2390's Avatar
There may be an adjustment screw?
There may be an adjustment simular to a drum brake adjustment?
Or, tighten up the center cable adjustment and you might have to add a spacer, steel tubing, between the adjustment nut(s) and cable U-bracket?
jrgearhead
Aug 22, 2011 08:30 PM
hopper146
May 17, 2011 10:55 AM
rebelrouser
Dec 19, 2010 04:39 AM
jp 71 camaro
Nov 7, 2010 08:36 PM
