cowl induction
Old Dec 11, 2006 | 02:47 PM
hateandanger's Avatar
Default cowl induction
i have a 92 camaro rs with a fiberglass cowl induction hood and was wondering what i would have to do to make it a functional scoop. i was thinking about jus turning my airbox around but am scared then it rains im going to hydrolock her. what modifications whould i have to do. Thanks help and advice is always appreciated.
Old Dec 11, 2006 | 04:33 PM
MadMikeZ28's Avatar
Default RE: cowl induction
I had a harwood on my 84 and thought about this.
I was thinking a smaller air cleaner lid just the size of the filter so it is opened around it. Or the k&n filter top.
A plate with a hole in it riveted to the inner structure to close off the rest from the cowl opening.
Seals on the plate and cleaner bousing.
Possible due to the lines rain will blow off the windshield but you might not have the high pressure there like the originals. And if the rain is still a big worry the air cleaners pick up from the front where water could still get in from while driving.
Old Dec 11, 2006 | 09:13 PM
vettemanosteel's Avatar
I got the k&N filter top for my air cleaner then some thick foam and thin sheet metal from the hardware store. I made th foam into a ring that fits around the base of the aircleaner lid that seals up against the hole in the hood and wrapped the foam ring with the sheet metal to insulate it from the engine heat and give the foam some suport. Works great, when you open the hood after driving around the filter top is just as cool as the air is outside...
anthony7888
Apr 8, 2011 08:30 PM
Swiss
67-69 V8 Tech
Aug 16, 2010 12:50 PM
bd92rs
Jan 11, 2010 10:46 AM
mikes77camaro
Aug 28, 2008 01:32 PM
91CamaroGuy
Oct 29, 2007 06:00 PM
