69 camaro.. Bbc valve cover spacer... Need advice
Old Oct 25, 2018 | 01:24 PM
Wassim's Avatar
Default 69 camaro.. Bbc valve cover spacer... Need advice
Hello.. I Need to fit a bbc 427 engine with factory chromed valve covers under my 69 camaro hood...the heads have 1.7 pro comp magnum rollers and the studs are hitting the valve covers... Also I am running 11" power brake... So the clearance with it is also an issue... I checked for spacers and i found 1/2, 3/8, 3/4, 1.15" etc. Spacer... Anyone have any idea what would be the best choice for my application... And yes the factory style valve cover is a must because i like to preserve the factory look under the hood.
Thank you in advanced.
Old Oct 25, 2018 | 05:05 PM
flat tire's Avatar
math is your friend MEASURE
Old Oct 25, 2018 | 11:03 PM
Wassim's Avatar
Math is everyones friend... But the engine is outside the car and can't do the measurement from outside... I am sure that someone has experienced my case...
Old Oct 26, 2018 | 07:59 AM
Zspoiler's Avatar
Try using long studs them see how tall you need for a spacer.There are also valve covers with a notch for big block Corvettes as well.
Old Oct 27, 2018 | 07:53 AM
flat tire's Avatar
don't know if this helps, but I run 4" valve covers on a sb that sits on BB frame mounts and have an 11" booster. plenty of room between the two
Big Ern
Jun 22, 2017 12:31 PM
Camaroboi22
Sep 16, 2012 05:28 PM
gfrench
Feb 27, 2011 09:48 PM
wizard148
May 8, 2008 09:54 AM
1969 Camaro
Aug 27, 2006 01:16 AM
