67 Camero Carb
Old Aug 16, 2009 | 02:53 PM
Old biker trash's Avatar
Default 67 Camero Carb
Bought a 1967 Camero convert a year ago to have a car to drive because all my rides are being restored by me and that ain't working to quick. This car was supposed to be turn key with 10 actual miles on rebuild - but - surprise. Present problem is - Quadrajet that won't adust. Thinking about replacing with Holly. Anybody have suggestions on this. Just want it to run reliable - no racer - just smooth and constitent. Also, after rewiring convrt top to proper 30 amp breaker, I have replaced the switch 3 times now and it keeps going bad, same symtoms. One side of rocker switch won't work and other side works fine. Top goes down, but will not come back up. Turn switch around and top won't go down, but will go up. I'm on 4th switch. Wondering if cast alum keeper is warping switch? Anybody else have this problem.
Old Aug 19, 2009 | 12:07 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
What size motor? holley is a good product, as is Edelbrock. a 650 might be fine.
Old Aug 19, 2009 | 11:37 AM
Motor is 327, 275 h.p. with automatic. Can't seem to get quad to idle down in park/neutral. Idle adjustment screw is backed out, but linkage won't even pull back far enough to engage adjustment screw. What am I missing here? It should be simple, but it has been a while since I messed abround with quad carb. I'm thinking about the 650 holley, unless this is a simple fix that I just don't see. If you have any suggestions to try, I'm game. If not, a purchase will be made. Thanks for any help you can offer.
Old Aug 19, 2009 | 01:34 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
If memory serves me there is alot going on with those carbs. I think there are two screws. I think your linkage is placed wrong somewhere,, either at the carb or the pedal. I suggest buying a service manual too.
Old Aug 19, 2009 | 02:44 PM
Make sure your choke is opening all the way, and that the fast idle pawl is dropping out of the way of the fast idle adjustment screw.
Old Sep 13, 2009 | 04:57 PM
jim fowler's Avatar
sorry to say its junk replace it do you want to sell the car
MB1969
Aug 6, 2010 08:50 PM
albo1989
82-92 V8 Tech
Jul 1, 2010 07:40 PM
Halodude
Jan 18, 2007 11:59 PM
rstoneman
Oct 1, 2006 06:22 PM
brett
Aug 31, 2006 01:19 AM
