LT1/LT4 Tech 1993-1997
94 camero Z28
Old Jun 27, 2005 | 02:13 AM
brett's Avatar
Default 94 camero Z28
i just recently bought a 94 camero Z28 and i want to put an after market exhaust system and i know it is almost impossible to fit dual exhaust on those cars, but can u fit dual exhaust on this year? How does the car run if u cut the cats out?
Old Jun 27, 2005 | 03:04 AM
JD1969's Avatar
Default RE: 94 camero Z28
It can be done but most people will either run turn downs before the rear axel, or run pipes out the back under the axel (it's not as bad as it seems). Removal of the cats on a 94 car is alittle tricky because it is an OBD1 car,if there are two sets of O2 sensors you might be able to use O2 simulators to "trick" the computor into thinking the cats are still there. I am not real familiar with the LT1 cars so I might be off base here, but it is worth looking into.
Old Aug 31, 2005 | 10:12 PM
TB561's Avatar
http://www.texas-speed.com/item_deta...ProductID=1241
3" catback dual exhaust x pipe mandrel bent
Old Sep 21, 2005 | 01:49 AM
nickyeper's Avatar
i got dual flowmaster cat-back system on my 94
Old Sep 21, 2005 | 02:27 AM
JD1969's Avatar
ORIGINAL: brett
You can run true dauls, it will be a custom system, you can delete cats as well and as it is an OBD I car the computor should be fine, just don't get caught it can be a hefty fine, (I don't have them on my car either though so shhhh)
Old Sep 21, 2005 | 07:37 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
i dont really think that straight pipes would really flow that great honestly. ive put custom systems on some of my cars, and it flowed like crap. Flowmaster or Borla all the way
Old Aug 31, 2006 | 01:19 AM
ANARCHY67's Avatar
yes borla is da shizznit
Weldinchevys
Jul 7, 2014 06:43 PM
MB1969
Aug 6, 2010 08:50 PM
Halodude
Jan 18, 2007 11:59 PM
rstoneman
Oct 1, 2006 06:22 PM
