67 Camaro shifter lever w/350 turbo?
Old Oct 11, 2015 | 02:27 PM
bevrsss's Avatar
Default 67 Camaro shifter lever w/350 turbo?
I am trying to install the OEM automatic shifter in my wife's '67 Camaro. Someone had put in a "slap-stick racing shifter, and cut the floor pan! I have the correct original shifter, and shifter rod and trans lever from Year One. My problem is the shifter lever that the shift rod attaches to, hits the transmission case on the side, near the extension housing! Do you have to heat and bend the OEM shifter lever, or can you purchase an after market shifter lever that clears the trans case? Any help would be appreciated! Thanks ~ Les
doboy3
Apr 29, 2011 05:52 PM
Tom071
70-81 Transmission & Differential
Feb 24, 2011 10:27 AM
kocuba
Jan 25, 2011 10:21 AM
GPyo05
Jul 21, 2010 09:41 AM
Bzman
Apr 13, 2010 02:46 AM
