67 camaro
Old Jul 17, 2013 | 11:22 PM
NAZ's Avatar
NAZ
haha that would be pretty sick if it was ejector seats
Old Jul 17, 2013 | 11:46 PM
Originally Posted by NAZ
would that have to be attached to the starter? because the wires from the red button end up leading to the starter. but ill have to check if they aren't corroded or detached from it.
Start wire from the switch to the starter. Somebody would have had to re-do the wiring to run that line through a switch, if that's what was done. You say the wires from the button go to the starter? Trace them to see where they connect.
Old Jul 17, 2013 | 11:48 PM
Since this thread is a tech question, I moved it to the 1st gen section.
Old Jul 18, 2013 | 08:31 AM
Everett#2390's Avatar
Good advice given. First Gens didn't have PUSH-TO-START buttons, but as said, may be a PO installed ejector seat, or missile launcher...
In the other forum, you did not include the PTS switch in your description of the no start problem.
I suggested there the symptoms you are observing are unusual, as you said the warning lights come on, but you have no headlamps or brake lights. The Camaro has one power wire from the engine compartment.
Comes through the firewall and ic rimped with leads to fuse panel, ign switch, and headlamp switch.
Ign sw powers the warning lights and ign power is parallel with headlamp power. Strange to have one and not the other, but, stranger things have happened.
As suggested, you trace the wires to/from starter, and let people know where they go. Voltage on them?
Old Jul 18, 2013 | 03:47 PM
NAZ's Avatar
NAZ
i followed the cables from the red button to the solenoid on the starter. could it be that my solenoid is bad?
Old Jul 18, 2013 | 04:33 PM
Both wires on the button go to the starter solenoid? When you said earlier "We were able to start without using the key", I presume you were jumping the terminals at the solenoid, or in some similar fashion? With that being the case, your solenoid can't be bad.
Old Jul 18, 2013 | 05:53 PM
NAZ's Avatar
NAZ
Maybe it's a bad wire that runs from the button to the solenoid?
Old Jul 18, 2013 | 06:08 PM
Or, one wire coming from somewhere else (presumably the ignition switch) and the other wire from button to the starter?
Old Jul 18, 2013 | 08:36 PM
One wire would connect with the positive battery cable stud,
the other wire would connect to the S terminal on the solenoid.
Old Jul 19, 2013 | 12:20 AM
  #20
NAZ's Avatar
NAZ
So I found out the problem its most likely a faulty neutral safety switch because i put the car in neutral and it started right up. But it wouldn't start when it was in park, so I'm going to take a look at that more tomorrow and find out for sure. However i never did get that red button to work so i removed it from the solenoid, it could just be a broken button or something. But thank you guys for the help and knowledge.
