4 speed shifter
Old May 10, 2012 | 08:34 PM
mikes68's Avatar
Default 4 speed shifter
i have a hurst indy shifter and linkage on my 68 with a saginaw trans, and i have a stock camaro muncie shifter and linkage would it be possible to use the indy linkage with the muncie shifter and have it fit in the console ??
Old May 10, 2012 | 09:41 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
ur talking about the handle right? they should all interchange if the two bolt holes line at the bottom line up unless it the older style munice base.
Old May 11, 2012 | 06:05 AM
dynarider33's Avatar
Your Camaro muncie shifter should have the offset shifter handle for the console (so you can get it in reverse). Try this link to help you out.
Camaro - Transmission
mikes68
Sep 19, 2011 08:56 PM
blowitup
May 1, 2010 09:46 PM
dynarider33
Mar 29, 2009 07:36 PM
69camaroaddict
Jun 21, 2007 12:57 AM
scrounger
Apr 27, 2007 05:29 PM
