1968 Camaro Z28 shifter not in center of hole.
1968 Z28 shifter hitting back of hole in tunnel in 2nd and 4th..looks like guy before me cut the tunnel back so it would shift.any thoughts???it a Muncie M22 with Hurst.thanks.
Well maybe a different shift lever would help,Hurst makes a bunch of different levers for their shifters.
It's been decades since I messed with one and it was on a T-10 in a '69 but something in my memory seems like there were a couple different mounting holes in the shifter mounting bracket or trans and different length rods available.Then again I could be remembering something else. lol
Shifter box can be rotated forward , insert 3/16 inch welding rod into alignment holes of box and shift levers and readjust linkage.
Or, as Y2K suggests, get another stick. Or add a spacer under the trans mount on crossmember.
I agree with the above options. A new shift lever would be your easiest option. I cut my floor a long time ago and I have regretted it ever since. Since then, I have my Hurst shift lever custom bent to fit. Turned out great, but now got a gaping hole I need have to weld back.
