Muncie shifter question
Old Jan 2, 2014 | 03:08 PM
Gregt909's Avatar
Default Muncie shifter question
I recently replaced a Saginaw with a Muncie. The linkage lined up a little different and now my shifter seems too far to the right (passenger side). My current Hurst shifter had a slight off set towards the passenger side. Question is there a shifter that has an off set towards the driver side? If so, I think it would center perfect. Please see picture to see what I'm referring to. Thanks.
Old Jan 2, 2014 | 03:11 PM
Gregt909's Avatar
Here's another pic right side up
Old Jan 2, 2014 | 04:49 PM
Years ago I had a different 69. The Hurst shifter was too close to the drivers side, so I heated up the stick with a torch and put a dog-leg (over & up) bend on it, right above where it bolts to the shifter so you won't see it. Cheaper and easier than replacing the shifter.
marks69ss
Jan 24, 2013 05:12 PM
97slpss
Apr 19, 2009 05:39 PM
73 T Top
Apr 28, 2007 10:35 PM
iakcfan1@yahoo.com
Nov 27, 2006 09:05 PM
gen1camaro
Oct 16, 2006 01:02 AM
