Looking for a 700r4 need tips
Old Jan 3, 2014 | 10:42 PM
1969's Avatar
Default Looking for a 700r4 need tips
My camaro is at like 3000 rpms at 60mph so im thinking a O/D tranny might make a good addition.
Is there a certain one i should be looking for? From a certain vehicle etc?
Is there alot to this conversion?
Old Jan 4, 2014 | 10:46 PM
MKCoconuts's Avatar
Post 85 and pre 93 is what you'll want to find. As for the swap itself, pretty sure you'll need a new crossmember and possibly a shortened driveshaft.
Old Jan 5, 2014 | 07:58 PM
Milan's Avatar
I just did a swap on my 67. Went from a 4 speed to 700r4. The best thing i have done in a long time. With 4:11 rear end my RPM at 60 was 3000. Now at 65 MPH the rpm Is at 2200. You will need a crossmember, shortened drive shaft, kickdown cable and bracket, and have a tranny shop wire the tranny.
Old Jan 6, 2014 | 07:21 AM
YAV8's Avatar
Or you could use the 200r and not need to shorten the drive shaft. Little better spacing in the gear ratio also.
Old Jan 8, 2014 | 06:29 AM
Jim-Bob's Avatar
..I'm also interested in some info..what years was the 200r used and what factors would determined using one over the other..the engine??
Thanks
MelloYello
Oct 19, 2010 06:05 PM
91camaro350
82-92 V8 Tech
Aug 2, 2010 05:37 PM
Dakota_Don
Apr 3, 2010 12:46 PM
got3ofem
Jun 26, 2008 09:47 PM
