89 700r4
Old Apr 3, 2010 | 12:46 PM
Dakota_Don's Avatar
Default 89 700r4
Hello i am rebuilding a 700r4 that burned up the 3-4 clutch pack, the tv cable broke and the owner kept driving it..
anyway i replaced them using the alto power pack, with clearance at about .030
also the 3-4 accumulator bore is scortched in the case.
I called trans-go since im using thier kit, They said to block off the bore by using two pistons with the ribs facing each other, and to make sure i install the sealng rings..
anyone do this? how harsh is the 3-4 shift after this?
should i block the feed hole? if so which hole is it?
a photo would be nice..
thanks
Don
91camaro350
82-92 V8 Tech
Aug 2, 2010 05:37 PM
359pete
Feb 15, 2009 12:58 PM
kyleag89
Jan 16, 2009 01:10 PM
sinisterRS
Apr 15, 2008 03:45 AM
HaloNick
May 1, 2006 06:09 PM
