10 Bolt Rear End
Old Mar 1, 2008 | 06:52 AM
  #21
skar's Avatar
Default RE: 10 Bolt Rear End
OK In my 68 RS I now have a 327 . Last year I had a Auburn pro limited slip installed with a 3:55 gear and a performance alum, cover (10 bolt 8.2). Car has a t-350 trans. Long term goal it to buy a 383 stoker 400- hp crate motor and 700r trans. Car will never see the track with street tires only. I will not beat on the car to bad. (Hole shoot here &there) Will this 10 bolt hold up.
Old Mar 1, 2008 | 07:19 PM
  #22
firebird69racer's Avatar
ORIGINAL: skar
YES
Old Mar 3, 2008 | 09:41 PM
  #23
bigdog84's Avatar
In my current '68 I'm running a 12 bolt 3.73 posi. In my dad's '68 he has a 10 bolt 3.73 posi. His engine setup dynos around 425. He was worried about durability as well. Uponthe suggestion of a local drag racer we installed a Summit differential support cover (see link below). It will fit the 8.2/8.5 in. 10 bolt rear and has 2 high strength bolts that run through the middle of the housing to prevent breakage. Unless you are running extreme HP I would not worry about your 10 bolt. If you are, install the support cover and I think you'll be great.
http://store.summitracing.com/partde...p;autoview=sku
Old Mar 4, 2008 | 03:49 PM
  #24
skar's Avatar
bigdog84
Thanks. I have one one the car.
MusicMan
Sep 29, 2008 06:25 PM
nzink
Apr 4, 2008 01:29 AM
mcge383
Nov 7, 2006 09:56 PM
cabowaboz28
Jul 29, 2006 01:58 AM
