10 bolt rear
Old Apr 1, 2008 | 01:29 PM
nzink's Avatar
Default 10 bolt rear
Im wondering whats the fastest 1/4 mile pass anyone here has made on their stock rear end? I'm planning on hitting mid to high 12s this season, and were gonna see how much the rear endcan take. When itdoes shellI'm gonnahave to put in a ford 9 inch. Buti havent had any problems with itso far....
Old Apr 1, 2008 | 01:43 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: 10 bolt rear
is the 3rd gen 10bolt a 7.5"? I have heard of 4th gen guys going 10s on them but everyone realizes you are on borrowed time. i have even seen a guy lift the front wheels on a 10bolt...... again, u just need to remember that youhave the potential to break things. I would say mid12's are fine unless you are talking about doing it with high rpm launches. if you have the power to go 12s on DR's you should be ok, just stay away from slicks
Old Apr 1, 2008 | 01:58 PM
nzink's Avatar
i believe 85 was the first year for the 7.625 rear actually, i cant remember off the top of my head. I've got a 3200 stall, but i only launch at about 1500...and slicks are all i have now, once i burn up my radials i will replace them with some good DRs and run those..
Old Apr 1, 2008 | 02:01 PM
Ninja Administrator
low launches like that wont be an issue. However you could stand to launch a little higher. just preload by hitting brake and reving engine up to just below stall. if you already have pressure on ur rear you are less likely to brake anything
Old Apr 1, 2008 | 02:23 PM
nzink's Avatar
totally agreed ^ i may start launching a little higher, but i've just been trying to take it easy on the rear for now is all
Old Apr 1, 2008 | 02:29 PM
Ninja Administrator
im not much into racing autos so i may be wrong, but it seems to me that with a higher stall like urs, u are actually harder on the rear launching low and allowing the stall to "slap" the rearend when it hits its mark rather than pushing the motor there to begin with and pushing all gears into contact before the launch.
Old Apr 2, 2008 | 08:56 PM
nzink's Avatar
hmmm...i dunno, seems like this might work in theory but im not sure about that
Old Apr 4, 2008 | 01:29 AM
nzink's Avatar
welp, i will let you all know how it goes..i should have the car back on the track for the next race in a month, cross your fingers!
MusicMan
Sep 29, 2008 06:25 PM
srich1207
Mar 4, 2008 03:49 PM
mcge383
Nov 7, 2006 09:56 PM
cabowaboz28
Jul 29, 2006 01:58 AM
