10 Bolt Rear End
Old Nov 6, 2006 | 02:55 PM
mcge383's Avatar
Default 10 Bolt Rear End
i am looking for a 10 bolt rear end for my 1988 camaro. unfortunatly the car was stolen and recovered and when this happened the previous owner put a piece of **** mopar rear in it. and it just so happens its a little 7" something but anyway if you know of any one that i can get a 10 bolt rear end from please tell me. Thanks
Old Nov 6, 2006 | 03:12 PM
blackz87's Avatar
Default RE: 10 Bolt Rear End
Your local salvage yard would be your best bet. Any 3rd gen rear from a camaro/firebird v6 or v8 will fit with out a problem. Best choice would be a 9-bolt from 1989 being the best and having the better rear discs. 28 spline axle shafts and limited slip.
Also I think you are mistaken about a Mopar 7 rear being on the car. For one they would not fit without major mods, also the 10-bolt rear has only a 7 1/2 or 7 5/8 dia ring gear.
Old Nov 6, 2006 | 04:35 PM
MadMikeZ28's Avatar
Since you have an 88 are you sure your not looking at a Borg Warner. It will have 9 bolts in the cover.
Old Nov 6, 2006 | 05:31 PM
T10wheels's Avatar
Do the 88's have a nice rear end? I have the limited slip without the ratio option.
Old Nov 7, 2006 | 10:21 AM
mcge383's Avatar
i really dont think it is a stock rear end or even a chevy becuase the way they put the rear sway bar on was really jerry rigged. they used exhaust hangers to hold it to the rear end. and the thing is that this rear end has a soft drain plug in it. the only one to put in a soft plug was mopar thats why i think it is a mopar rear end. to answer your question about if they are good, well i have built 355 in my camaro and i've done some pretty nasty burn outs and yes i have raced and it has held up great but i'm getting ready to give it an attitude change if you know what i mean! and i need that extra strenght out back. Thanks for the information.
Old Nov 7, 2006 | 10:26 AM
blackz87's Avatar
Bw 9-bolts have the soft drain plug. What engine do you have??? Also do you have the RPO codes under the center condole lid?? Look for a GU__ codes for rear axle ID.
Old Nov 7, 2006 | 12:36 PM
FlufyTiger's Avatar
If you decide to keep the rear, and want to do away with the rubber plug, I have a chrome cover with a metal plug for a BW 9 bolt, I'll sell it to you for $15 plus shipping, and it's still in the box.
Old Nov 7, 2006 | 02:41 PM
mcge383's Avatar
ok thanks i didnt know that because i only seen soft plugs in mopars. my next question is how much power can the bw hold? oh and to answer your question it's a 350 but its def. not stock! thanks for all of the info.
there arent any codes under the console i think but ill have to go out to my storage tonight and check so ill get back to you with the codes.
Old Nov 7, 2006 | 03:38 PM
blackz87's Avatar
The BW 9-bolt was used on most 350TPI & 305TPI (5sp) cars as it was stronger then the 10-bolt.
Big difference was no "c" clips. 7.750 dia ring gear, 4 side pinins, stronger limited slip and later 28 spline ax Last year on production cars was le shafts. It came wiith only (3) gear ratios, 2:77 std on 350 cars, 3:27 option on 350 cars and 3:45 on 5sp cars. Early years did have a 3:08 & 3:70 ratios. Again it is a better rear then the 10-bolt, but was discontinued in 1989 as too expensive by GM. One disadvantage is that parts are to find.
Old Nov 7, 2006 | 09:56 PM
mcge383's Avatar
thanks a lot for the very useful info. i didnt have a clue about this rear end so thank you blackz87.
MusicMan
Sep 29, 2008 06:25 PM
nzink
Apr 4, 2008 01:29 AM
srich1207
Mar 4, 2008 03:49 PM
cabowaboz28
Jul 29, 2006 01:58 AM
