Front tire/rim swap
Old Mar 29, 2012 | 08:50 PM
Rozzy's Avatar
Default Front tire/rim swap
Was wondering if anyone has put the same width rim and tire on the front of a new SS/Camaro as whats on the back? If there are any clearance problems.
Old Jul 17, 2012 | 08:50 PM
Rozzy's Avatar
Default Thanks for Nothing
You know your worthless. Ask for help and a tard like your replies with crap.
Originally Posted by Truing
The wheel swap suggests to you that it is all about a changing of wheels. This is a trick which can save you a lot of trouble if you can't jump from one obstacle to another if the back wheel is too far behind or if the obstacle is too tall. Here is how you do it.
Old Feb 13, 2014 | 04:07 PM
Trickracen's Avatar
Front can run a 10 inch wheel with 275 with no problems, which is what you have most likely. Which stock wheels do you have?
If your stocks are the 8.5inch up front then I believe the widest those would accept are 255s
edit: just realized this was an old thread, sorry
67 engine revvin
Oct 18, 2016 01:48 PM
flowride
Jan 4, 2013 01:13 AM
Chaotic94
Oct 22, 2010 08:14 AM
doinbout150
Oct 8, 2007 09:32 PM
speedygolf
Sep 1, 2007 09:55 PM
