Front tire/rim swap
Was wondering if anyone has put the same width rim and tire on the front of a new SS/Camaro as whats on the back? If there are any clearance problems.
Thanks for Nothing
:icon_flamethrow: You know your worthless. Ask for help and a tard like your replies with crap.
Originally Posted by Truing
(Post 633556)
The wheel swap suggests to you that it is all about a changing of wheels. This is a trick which can save you a lot of trouble if you can't jump from one obstacle to another if the back wheel is too far behind or if the obstacle is too tall. Here is how you do it.
Front can run a 10 inch wheel with 275 with no problems, which is what you have most likely. Which stock wheels do you have?
If your stocks are the 8.5inch up front then I believe the widest those would accept are 255s edit: just realized this was an old thread, sorry :) |
