2010+ V6 Tech discuss modifications to the all new 3.6L v6 here.
New Camaro Owner-Need Some Basic Advice
Old Aug 12, 2018 | 05:50 AM
ChevyGuy3's Avatar
Default New Camaro Owner-Need Some Basic Advice
Hi everyone! This is my first post here and I wanted to get some advice, since this is my first Camaro. Just a few questions below...would appreciate your thoughts. My Camaro is the 2010 LT1 version with 96,000 miles on it.
1. Can I use regular, full synthetic oil (Pennzoil, Mobil 1, etc) or do I need to use Dexos? I have only ever put full syn. in my cars so I want to make sure I do this right.
2. What is the best octane gas to use in this motor (V6 3.6ltr, 304HP) I don't want the motor getting bogged down on low octane, so is it better to run 89 or 93 or can I still go with 87?
3.The dealership said they ran the car through there inspection process, but would you guys suggest changing the oil, trans fluid, etc anyways?
Thanks in advance!
Old Aug 12, 2018 | 10:47 AM
Y2K's Avatar
Y2K
#1=yes,hard to beat Mobil 1.
#2 = regular should be fine, higher octane is for high compression engines, if it doesn't knock or ping on regular gas premium is a waste of money.
The V-6 I believe is rated for 87.
#3= inspection? Unless that included a full service getting it done is not a bad idea, if you don't have service records to know when it was last done an inspection could mean just checking everything not necessarily doing a service.
Old Aug 12, 2018 | 03:27 PM
ChevyGuy3's Avatar
Thanks for the info-much appreciated!
sdotbailey
Oct 26, 2013 09:26 PM
SSTHUNDER
Mar 28, 2012 02:55 PM
valnzula
Jun 23, 2010 09:25 PM
Mesosneaky
Jul 8, 2009 10:02 PM
hsdragracer
Jun 28, 2006 03:55 AM
