High Octanne
Old Mar 27, 2012 | 07:14 PM
SSTHUNDER's Avatar
Question High Octanne
I am thinking about buying a pre owned 2010 Camaro SS. I was wondering if everyone uses high octane gas?
I am not buying this for the gas mileage but just wanted to know if you guys use and recommend high octane for such a powerful machine!!
All responses are greatly appreciated!!
Old Mar 27, 2012 | 07:31 PM
BasicConcepts's Avatar
Technical User
i always run 93 in everything i drive
Old Mar 27, 2012 | 09:03 PM
Use what the owner's manual calls for.
Old Mar 27, 2012 | 09:30 PM
MKCoconuts's Avatar
+1 on going by the user manual.
High octane, usually 93, is meant for cars with a high compression ratio, because it can be compressed more before exploding. Filling a car with a lower octane than it calls for will make the a/f ratio to explode before the stroke is finished, and before the spark plugs fire. This will put a lot of stress on all engine components, specifically the valves, piston head, and rods. The knock sensor is meant to prevent this...but like everything else, it can only do so much.
The same goes for cars that call for a low octane, such as 87. It's bad for the engine and a waste of money to put a higher octane in it. And from my experience, octane boosters do not work.
I've run my Camaro with 87 when I first got it. Then I realized I should be running 93. After finally getting a complete tank of just 93, the car ran flawlessy. Before it had some minor problems. I honestly don't mind paying $4.05/gallon ($3.79 back home).
Old Mar 28, 2012 | 09:44 AM
Chevrolet Customer Service's Avatar
Official GM Representitive
The owners manual for the 2010 Camaro SS requires 91 or higher octane fuel. The recommended gasoline would be top tier detergent gasoline with a rating of premium unleaded. I hope this helps to answer your question SSTHUNDER.
Jeff Morris, Chevrolet Customer Service
Old Mar 28, 2012 | 02:55 PM
SSTHUNDER's Avatar
Ok so go with the hight octane!
I thought this would be the best option but since I dont know too much about Camaros, figured I should ask.
Thanks Again!!!!!!
iLL95
Nov 25, 2011 10:41 PM
imcdowel
Mar 17, 2011 09:45 PM
MaVeN
Oct 23, 2010 01:33 PM
CNCman
Aug 4, 2009 08:06 AM
alma_mort
Mar 7, 2007 01:16 PM
