High RPM
Old Nov 25, 2011 | 05:31 PM
iLL95's Avatar
I Like to Party
Super Member
Default High RPM
Well I noticed I had a miss so I checked all my plugs and one was loose so i tightened it back up, made sure all the others were tight, triple checked the firing order, put everything back in and when I went to start it, it had a pretty strong start up but noticed it sounded like I revved it when it started and the RPM's stayed at 1500, Im going to get a new IAC soon and cleaned the MAP sensor, im a bit confused at this point, I know all the wires are correct and none are crossing, im going to get a scanner soon (they're pretty expensive) But I wanted to DIY it without one but reliazed that it would help to always have one on my sad. Any ideas?
Old Nov 25, 2011 | 05:52 PM
Failed Devices's Avatar
is is throwing a code? could just go to autozone or somewhere and ask them to scan for you.
Old Nov 25, 2011 | 10:41 PM
iLL95's Avatar
I Like to Party
Super Member
Fired her up, sounds better, must have been a 1 time thing. I'm still going to scan it though
imcdowel
Mar 17, 2011 09:45 PM
MaVeN
Oct 23, 2010 01:33 PM
CNCman
Aug 4, 2009 08:06 AM
microkid
Mar 17, 2007 04:26 PM
alma_mort
Mar 7, 2007 01:16 PM
