Problems with 2010
Old Jan 6, 2018 | 02:54 PM
Rsaavedra's Avatar
Default Problems with 2010
IM new with this and bought a 2010 LS. Back in August and since then I have had to change the time belt. . Water pump and intake hose. My ESL came on. Code read for cat converters. Then it went off. Should i replace them ? Can I rip them out ?
Old Feb 4, 2018 | 12:39 PM
ricksza's Avatar
Chances are if you are getting catalytic converter codes, the cats are going bad. You might get lucky and have weak o2 sensors. this would need to be checked with a scanner. If you remove them, the light will come on and stay on. It is illegal by Federal laws to remove them and if your car is required to have emission inspection it will fail.
libertyforall1776
Mid West
Jul 22, 2010 02:06 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nightmaro
Oct 7, 2007 10:33 PM
