Car Loses Oil (Oil in the end air filter hose) !!!
Old Aug 8, 2017 | 11:42 AM
hussain112ali's Avatar
Unhappy Car Loses Oil (Oil in the end air filter hose) !!!
Hi guys ... I need your help badly
I'm driving the 2LT V6 2012 Camaro
My car loses oil (Around 1-2 liter per 150km)
- Car exhaust without bad smoke only if the RPM is above the 3k.
- No damaged spark plugs even after 3 months of the problem.
- RPM is stable.
- No oil on the outer side of the engine or leak points.
- No oil on the ground (Car not leaking oil out).
But I found a huge amount of oil on the end of the air cleaner hose,
coming from the breather tube !!!
Kindly check the attached pictures, and tell me what should I check before considering to open the whole engine ?
Attached Thumbnails Car Loses Oil (Oil in the end air filter hose) !!!-img_5652.jpg   Car Loses Oil (Oil in the end air filter hose) !!!-img_5653.jpg   Car Loses Oil (Oil in the end air filter hose) !!!-img_5654.jpg   Car Loses Oil (Oil in the end air filter hose) !!!-img_5655.jpg
mab6680
Dec 23, 2010 08:01 PM
jason7504
Aug 19, 2008 12:50 PM
jessi78
Jun 15, 2008 06:38 AM
nece$$aryevil
Dec 9, 2007 08:45 PM
vampyrico
Mar 30, 2007 03:24 PM
