Car Loses Oil (Oil in the end air filter hose) !!!
4 Attachment(s)
Hi guys ... I need your help badly
I'm driving the 2LT V6 2012 Camaro :icon_steer: My car loses oil (Around 1-2 liter per 150km) - Car exhaust without bad smoke only if the RPM is above the 3k. - No damaged spark plugs even after 3 months of the problem. - RPM is stable. - No oil on the outer side of the engine or leak points. - No oil on the ground (Car not leaking oil out). But I found a huge amount of oil on the end of the air cleaner hose, coming from the breather tube !!! Kindly check the attached pictures, and tell me what should I check before considering to open the whole engine ? |
