2010 shift light help
I purchased an Auto Meter quick-lite shift light along with rpm module #5330. I am not sure where to hook up the rpm pick up. I do not have a wiring diagram for my car so I am not sure if there is a pcm pin to use like on previous models.
Any help would greatly be appreciated
Update:
Upon further research I found out a DIS tach adapter/driver is needed when installing a shift light or after market tachometer on the fifth generation camaro. Hopefully this information will help someone else too.
Auto Meter part #9117 or
MSD part number #8913
The Auto Meter website has detailed instructions on wiring this up properly.
