shorten belt?
Old Jul 3, 2005 | 03:56 PM
Camarok's Avatar
Default shorten belt?
if i take off my compressor and my smog pump since there not being used and get a shorter belt? would that be good? and help in horse but as well for weight reduction? is there a shorter belt just to run on power steering,water pump,crank, and driveshaft? i think those are the main ones
Old Jul 3, 2005 | 04:44 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: shorten belt?
yea they have belts in all sizes and it probably would help hp, and definitly weight
Old Aug 11, 2005 | 11:17 PM
nj02z28ls1's Avatar
it is not even worth the hasle unhooking the smog equiptment, then you have to re-write the ecu because of the trouble codes the motor is going to throw out thats even if it starts. get a under drive pully system to slow down your strain on the motor, and if you run it at the track get a shorter belt to bypass the a/c. autozone has all the belt sizes on their computer and can match you up on for your application.
bd92rs
Jun 11, 2011 07:26 AM
gfrench
Nov 5, 2010 07:27 PM
slong1958
Aug 19, 2009 11:33 AM
Spartan66
Apr 5, 2008 09:01 PM
airchevy02
Oct 6, 2006 01:17 PM
