stripped steering wheel bolt
Old Sep 5, 2010 | 04:30 PM
joe86's Avatar
Default stripped steering wheel bolt
I have a 1985 chevy camaro z28 and the center bolt that holds the steering wheel on is now stripped. some of the threads are bent and messed up. the bolt looks like a regular bolt but it also has teeth on it to that slid into the steering wheel. My question is can i replace that bolt? and if so what is that part called and if not then what do i do because the nut acts like it is threading on and then it pops off.
Old Sep 9, 2010 | 02:46 PM
Caveman305's Avatar
if its a tilt column then that bolt is actually a part of the ball socket that connects about a 1/4 of the way down the column(right where it pivots), you would need that whole piece from another camaro, something that may be easier would be to buy a new*used* column and replace the whole thing
you can find write ups for dissasembling the third gen steering column, if you want i can PM you the link
Jim-Bob
Nov 10, 2012 06:45 AM
BasicConcepts
Dec 3, 2011 03:00 PM
kocuba
May 21, 2011 04:04 PM
baarf
Jul 30, 2010 10:31 PM
xkpw
Dec 29, 2009 11:49 AM
